Date/Time: Sun, 16 Mar 2025 08:26:28 +0000
Studies not loading on Windows 11, Paralells with Mac
View Count: 480
[2022-08-11 02:20:44] |
User354736 - Posts: 2 |
I'm having an issue getting any studies and content to load and open on SC. Using a Macbook Pro M1 Pro with Parallells and Windows 11, 64bit SC app. Has anyone else had an issue like this? I've disabled all antivirus and firewall blocks I can find. |
[2022-08-11 05:52:04] |
Sierra_Chart Engineering - Posts: 18797 |
Are you referring to custom studies?
[2022-08-11 11:47:37] |
It was actually all studies, but I've found a solution. I re-downloaded the zip file and started over once virus protection was gone. Windows must have stripped it and the automatic SC reinstaller was not working. Thank you!
[2022-08-11 12:02:04] |
Yes if it was the built in studies that were affected, we would have suggested to reinstall Sierra Chart.
