Date/Time: Fri, 07 Feb 2025 14:49:45 +0000
Color Bar Based on Study/Above Below
View Count: 561
[2022-08-10 17:00:54]
Alex C Demosthenes - Posts: 50
Hi - I am using the Color Bar Based on Study/Above Below and wondering if I could use this study to check for 3 separate conditions rather than the condition of just 1 study? If not, which study would be appropriate to evaluate for 3 conditions, or would this require advanced programming?
Date Time Of Last Edit: 2022-08-10 17:02:24
[2022-08-10 18:32:54]
John - SC Support - Posts: 37808
You would want to use the "Color Bar Based On Alert Condition" instead, which allows for more flexibility.
Then within your Alert code, you would use AND and/or OR functions to tie the different conditions together. Refer to the information on writing Alerts at the following link:
Study/Chart Alerts And Scanning: Alert Condition Formula Format
And refer to the information for the Color Bar Based on Alert Condition here:
[2022-08-10 19:55:31]
Thanks for the detailed response!!
