Date/Time: Sun, 16 Mar 2025 03:00:46 +0000
Denali Exchange Data Feed doesn´t work
View Count: 427
[2022-08-10 16:58:21] |
Adrian Aragione - Posts: 1 |
Hello all, when i start sierrachart, the historical data are loading. but then, there is no real-time update. when i disconnect and connect again, the chart is updating the gap, but there is still no "live"-datafeed. Hiw can i solve this problem? Best regards |
[2022-08-10 18:30:41] |
John - SC Support - Posts: 38678 |
You have not gone through the process to setup the Denali Exchange Data Feed. What are the exchanges for which you want real-time data? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
