Date/Time: Sun, 16 Mar 2025 02:55:05 +0000
I can't upload a chartbook
View Count: 697
[2022-08-10 16:45:08]
User707307 - Posts: 84
Here I have this chartbook. When I try to upload it to the platform I get the follwoing message; The chartbook file is not compatible, Contact Sierra Chart for support for help with converting it.
The file is attached. Thank you.
attachmentMP_RTH_ETH.cht - Attached On 2022-08-10 16:44:52 UTC - Size: 68.79 KB - 236 views
[2022-08-10 18:05:36]
John - SC Support - Posts: 38678
Your updated file is attached.
attachmentMP_RTH_ETH.cht - Attached On 2022-08-10 18:03:18 UTC - Size: 5.62 KB - 247 views
[2022-08-10 18:27:08]
Hello again, I can't download it on the right format to open it in Sierra
What can be the issue?
Thank you
[2022-08-10 18:43:11]
Here I have some more files that need the same work
attachmentVolumeprof footprint.Cht - Attached On 2022-08-10 18:42:35 UTC - Size: 8.51 KB - 241 views
attachmentSteenbarger-Adjusted-NYSE-TICK.Cht - Attached On 2022-08-10 18:42:46 UTC - Size: 10.88 KB - 179 views
[2022-08-10 18:43:54]
MORE
attachmentSession and intermidiate volume prof 10 min chart.Cht - Attached On 2022-08-10 18:43:34 UTC - Size: 70.18 KB - 488 views
attachmentPlaybook Footprint and heatmap.Cht - Attached On 2022-08-10 18:43:49 UTC - Size: 41.3 KB - 307 views
[2022-08-10 18:44:21]
MORE
attachmentJigsaw Heatmap.Cht - Attached On 2022-08-10 18:44:04 UTC - Size: 136.02 KB - 183 views
attachmentIndices chart.Cht - Attached On 2022-08-10 18:44:13 UTC - Size: 172.3 KB - 285 views
[2022-08-10 18:44:52]
MORE
attachmentFootprint volume and delta profile.Cht - Attached On 2022-08-10 18:44:35 UTC - Size: 33.71 KB - 120 views
attachmentES.Cht - Attached On 2022-08-10 18:44:50 UTC - Size: 1.68 MB - 114 views
[2022-08-10 18:45:50]
MORE
attachmentES BOOKMAP.Cht - Attached On 2022-08-10 18:45:07 UTC - Size: 21.26 KB - 263 views
attachmentDelta prof.Cht - Attached On 2022-08-10 18:45:14 UTC - Size: 5.3 KB - 291 views
Private File
[2022-08-10 18:46:38]
MORE
attachmentAdvanced Heatmap ES.Cht - Attached On 2022-08-10 18:46:21 UTC - Size: 143.07 KB - 281 views
attachmentAdvanced Heatmap CL.Cht - Attached On 2022-08-10 18:46:25 UTC - Size: 143.07 KB - 237 views
attachmentBid Ask Footprint.Cht - Attached On 2022-08-10 18:46:31 UTC - Size: 127.51 KB - 153 views
[2022-08-10 18:47:26]
MORE
attachmentCompare expiring futures contracts.cht - Attached On 2022-08-10 18:47:07 UTC - Size: 259.11 KB - 222 views
attachmentCL Bookmap.Cht - Attached On 2022-08-10 18:47:13 UTC - Size: 392.57 KB - 151 views
attachmentBid Ask Footprint.Cht - Attached On 2022-08-10 18:47:21 UTC - Size: 127.51 KB - 274 views
[2022-08-10 19:12:09]
Before we update your other chartbooks, you stated in Post #3 the following:
"Hello again, I can't download it on the right format to open it in Sierra
What can be the issue?"
Were you able to download the updated chartbook and use it or not? If not, what seems to be the issue?
[2022-08-10 19:28:54]
I wasn't able to use it, it seems like it's not on the right format after I download it from here.
The logo actually appears like the earth from sierra chart instead of the white sheet like it should.
Thank you
[2022-08-10 20:34:54]
Make sure the file extension has stayed as ".cht" (no quotes). And that the file is in the correct folder (the Data folder located under the main Sierra Chart installation folder).
If these are correct, then the icon should not matter and you should be able to open the chartbook through Sierra Chart.
Let us know if you are still having an issue with this.
[2022-08-10 20:47:59]
Ok it works now . You can go with the rest of chartbooks
[2022-08-10 21:12:17]
Attached are your updated chartbooks.
Note that you had also attached a .dll file, but there is nothing we can do with that. If it is not working, then you will need to recompile it yourself, if you have the original code, or ask the person that developed it for you to update it and compile it.
attachmentAdvanced Heatmap CL.Cht - Attached On 2022-08-10 21:10:09 UTC - Size: 7.1 KB - 300 views
attachmentAdvanced Heatmap ES.Cht - Attached On 2022-08-10 21:10:15 UTC - Size: 7.1 KB - 269 views
attachmentBid Ask Footprint.Cht - Attached On 2022-08-10 21:10:20 UTC - Size: 8.09 KB - 179 views
attachmentCL Bookmap.Cht - Attached On 2022-08-10 21:10:34 UTC - Size: 21.99 KB - 136 views
attachmentCompare expiring futures contracts.cht - Attached On 2022-08-10 21:10:41 UTC - Size: 19.51 KB - 228 views
attachmentDelta prof.Cht - Attached On 2022-08-10 21:10:47 UTC - Size: 8.98 KB - 278 views
attachmentES BOOKMAP.Cht - Attached On 2022-08-10 21:10:54 UTC - Size: 21.96 KB - 133 views
attachmentES.Cht - Attached On 2022-08-10 21:11:02 UTC - Size: 97.17 KB - 181 views
attachmentFootprint volume and delta profile.Cht - Attached On 2022-08-10 21:11:09 UTC - Size: 33.96 KB - 263 views
attachmentIndices chart.Cht - Attached On 2022-08-10 21:11:18 UTC - Size: 7.91 KB - 298 views
attachmentJigsaw Heatmap.Cht - Attached On 2022-08-10 21:11:25 UTC - Size: 9.36 KB - 273 views
attachmentPlaybook Footprint and heatmap.Cht - Attached On 2022-08-10 21:11:32 UTC - Size: 42.76 KB - 166 views
attachmentSession and intermidiate volume prof 10 min chart.Cht - Attached On 2022-08-10 21:11:42 UTC - Size: 7.4 KB - 284 views
attachmentSteenbarger-Adjusted-NYSE-TICK.Cht - Attached On 2022-08-10 21:11:54 UTC - Size: 12.18 KB - 279 views
attachmentVolumeprof footprint.Cht - Attached On 2022-08-10 21:12:00 UTC - Size: 9.47 KB - 264 views
