Date/Time: Sun, 16 Mar 2025 02:57:36 +0000
File size on disk
View Count: 425
[2022-08-10 12:50:27] |
User573482 - Posts: 6 |
Hello, The data folder on disk continues to grow and shows that size is close to 60 gb and size on disk is about 16gb. Is there a way to reduce the size? Thanks. |
[2022-08-10 16:46:22] |
John - SC Support - Posts: 38678 |
Yes delete the files that you do not need: Chart Data and Chart Data Files: Deleting a Chart Data File (Deleting chart data files) Also refer to: Intraday Data File Management (Intraday data file management) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
