Date/Time: Sun, 16 Mar 2025 02:57:35 +0000
problem with footprint visibility
View Count: 353
[2022-08-10 12:44:50] |
Daniel KamiĆski - Posts: 25 |
I am asking for some information on how to set data visibility because I can not set it normally. As I zoom in, I can only see a piece of data, when the price goes up, I cannot change the chart to the current data. Request for help. I am attaching a file |
![]() Attachment Deleted. |
[2022-08-10 13:18:38] |
Sierra_Chart Engineering - Posts: 18796 |
Refer to this section here: Numbers Bars: Adjusting Tick Size For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
