Date/Time: Sun, 16 Mar 2025 13:50:40 +0000
v.2422 bug with 'after single tool use change to' option
View Count: 492
[2022-08-10 05:52:22] |
User753428 - Posts: 172 |
after updating to v.2422, After Single Tool Use Change To option doesn't change to Hand despite having selected the Hand option. |
[2022-08-10 06:15:02] |
Sierra_Chart Engineering - Posts: 18797 |
This will be resolved.
[2022-08-10 16:28:38] |
John - SC Support - Posts: 38678 |
This has been fixed and will be available in the next Pre-Release (v 2423). When available, you can update by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-18 17:49:59] |
There was a fix to the fix to ensure that other issues would not come about from the first fix. In the end, you just need to go to the Tool Settings and select the option for After Single Tool Use Change To to whatever you need it to be. It will then stick around properly going forward.
