Date/Time: Sun, 16 Mar 2025 02:49:19 +0000
ORDER FLOW AND VOLUME PROFILE
View Count: 656
[2022-08-09 16:46:18]
Camilo Rodriguez - Posts: 3
Hello, could you please tell me which service package should I buy to be able to have order flow and volume profile? Thanks
[2022-08-09 17:08:46]
John - SC Support - Posts: 38678
You need to be on the Advanced Package in order to use the Numbers Bars (order flow) study.
If you are going to be connecting to your trading/data service or if you want real-time futures data from us, then you will need to be on Package 11.
Otherwise, if you are going to use our Delayed Streaming Data for testing, then you can use Package 5. Refer to the differences in the packages at the following link:
Description of Service Packages and Pricing: Packages
