Date/Time: Sun, 16 Mar 2025 02:57:36 +0000
Drawing then chart movement by
View Count: 332
[2022-08-09 15:25:19]
THANOS929 - Posts: 23
version 2422, when ever i make a drawing on a chart, in the past it would then revert to my setting of the "hand" and allow me to move the chart. Now I have to physically press the "hand" button in toolbar after every drawing, to then adjust or move my chart. I have not changed any settings that I am aware of. I have reverted back to version 19 and there is no problem.
[2022-08-09 16:10:40]
John - SC Support - Posts: 38678
The particular setting that controls what you are referencing is Tools >> Tool Settings >> General >> After Single Tool Use Change To.
We just tried this and this setting is being "blanked" out when upgrading to version 2422. We apologize for this and will look into it. In the meantime, if you upgrade, just go to the Tool Settings and set it to Hand.
