Date/Time: Sun, 16 Mar 2025 08:31:17 +0000
Alert for line tool in template
View Count: 391
[2022-08-09 14:57:43] |
User361939 - Posts: 167 |
Hello, i would like to create template for my horizontal line, e.g TC4, so when price touch line text alert will be triggered. Could you help me how can i achieve this result? Best Regards |
[2022-08-09 15:59:57] |
Sierra_Chart Engineering - Posts: 18797 |
First refer to: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-17 08:02:32] |
Is it possible to "Short name" this alert so it would appear accordingly in ALERT MANAGER?
[2022-08-17 13:51:53] |
John - SC Support - Posts: 38678 |
There are no options for alternative naming for Drawing Alerts.
[2022-08-17 13:55:02] |
Would you consider adding this option?
