Date/Time: Sun, 16 Mar 2025 08:33:46 +0000
ø
View Count: 463
[2022-08-09 14:27:55] |
sgne - Posts: 109 |
ø
Date Time Of Last Edit: 2024-12-05 03:50:16
[2022-08-09 15:59:46] |
John - SC Support - Posts: 38678 |
On the Spreadsheet System for Trading Inputs you need to set the Input for Send Orders to Trading System to No in order to use the system in Simulation Mode. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Send Orders To Trade Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-09 17:02:55] |
The other thing to check is that the options for Trade >> Auto Trading Enabled - Global and Trade >> Auto Trading Enabled - Chart are both enabled. We would like to look at the Chartbook, please attach it to this thread for us to take a look and see if we can reproduce what you are seeing. Follow these instructions to post the chartbook: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-10 17:10:26] |
Sierra_Chart Engineering - Posts: 18797 |
Regarding that error, refer to: Automated Trading Management: SendOrdersToTradeService Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-10 20:17:06] |
Make sure that Trade >> Trade Simulation Mode On is enabled. If not, this would be the cause of the error message.
