Date/Time: Thu, 10 Sep 2026 08:16:42 +0000
Numbers Bars Question
View Count: 934
[2022-08-09 13:54:40]
User939100 - Posts: 7
(translated from the German below)
If I only want to use one column in Number Bars, can I have the 4 volume bars in 4 colors and display imbalances at the same time?
If I don't set Column 1 to 25, 50, 75 in this setting but to my imbalance, I only have 3 colors in volume bars.
Column # percent comparison thresholds
This section applies to each of the 3 Column # Percent Comparison Threshold Inputs .
The # Percent Comparison Thresholds column is a text string input with 3 values ​​separated by commas. The default values ​​are .25 , .50 , and .75 . The leftmost value is considered the first comparison threshold and the rightmost value is considered the third comparison threshold.
The 3 comparison thresholds represent percentage values. 0.01 equals 1%. So 1.0 is 100 percent.
Each of the thresholds must be separated by a comma.
It is necessary that these threshold values ​​are arranged in ascending order from left to right. If they don't, they don't match the color settings correctly.
These percentage comparison thresholds are used to determine which of the four comparison ranges a number bar value falls into. These comparison areas correspond to the 4 Up Color and 4 Down Color settings for each number bar column.
See Number Bar Color Settings and Logic for detailed explanations of each background and text color method.
Wenn ich in Number Bars nur eine Columne nutzen möchte kann ich mir die 4 Volumenbalken in 4 Farben und gleichzeitig Imbalancen anzeigen lassen ?
Wenn ich in dieser Einstellung Columne 1 nicht auf 25 , 50 ,75 sondern auf meine Imbalance einstelle habe ich nur noch 3 Farben in Volumenbalken .
Spalte # Prozent Vergleichsschwellenwerte
Dieser Abschnitt gilt für jeden der 3 Spalte # Prozent-Vergleichsschwelleneingänge .
Die Spalte # Prozentvergleichsschwellenwerte ist eine Textzeichenfolgeneingabe mit 3 durch Kommas getrennten Werten. Die Standardwerte sind .25 , .50 und .75 . Der Wert ganz links wird als erster Vergleichsschwellenwert betrachtet und der Wert ganz rechts wird als dritter Vergleichsschwellenwert betrachtet.
Die 3 Vergleichsschwellenwerte stellen Prozentwerte dar . 0,01 entspricht 1 %. 1,0 ist also 100 Prozent.
Jeder der Schwellenwerte muss durch ein Kommazeichen getrennt werden.
Es ist erforderlich, dass diese Schwellenwerte von links nach rechts aufsteigend angeordnet sind. Wenn dies nicht der Fall ist, stimmen sie nicht korrekt mit den Farbeinstellungen überein.
Diese prozentualen Vergleichsschwellenwerte werden verwendet, um zu bestimmen, in welchen der vier Vergleichsbereiche ein Zahlenbalkenwert fällt. Diese Vergleichsbereiche entsprechen den 4 Up Color- und 4 Down Color-Einstellungen für jede Zahlenbalken-Spalte.
Siehe Farbeinstellungen und Logik für Zahlenbalken für detaillierte Erklärungen für jede Hintergrund- und Textfarbmethode.
[2022-08-09 15:15:50]
John - SC Support - Posts: 47822
We are not fully understanding your question/issue.
There are 4 colors and the percentages (or Actual Values) are setup to go from 0 to the first number and then from the last number to 100%. So for example, if you have Percent Compare Values of 25, 50, 75 then your 4 colors would map to the following:
- 0 - 25%: Up/Down Color 1
- 26% - 50%: Up/Down Color 2
- 51% - 75%: Up/Down Color 3
- 76% - 100%: Up/Down Color 4
If you need more help, then please give us more information on the particular issue you are having so we can understand better.
