Date/Time: Sun, 16 Mar 2025 02:55:02 +0000
denali data feed trial request
View Count: 389
[2022-08-09 13:31:55]
User788124 - Posts: 5
hi there, i wish to have acces to denali data feed trail to try teton routing on sierra chart please
[2022-08-09 14:49:24]
John - SC Support - Posts: 38678
We have reset the trial for your account, so you can use the system, in general.
But in terms of getting the data, you would need to be on one of the paid Integrated packages.
Have you setup an account with a broker that supports the Teton Order Routing Service yet? If not, then this would be the first step. Refer to the Setup Instructions at the following link for how to get the Teton Order Routing setup:
Sierra Chart Teton Futures Order Routing: Setup Instructions
