Date/Time: Tue, 26 Nov 2024 11:53:51 +0000
Where are symbols: KRW (Korean Won), IBAA (Bovespa index) etc???
View Count: 1769
[2014-05-10 18:30:31] |
User59863 - Posts: 36 |
1/ Why do we always have to ask for each & every symbol on IB (Interative Brokers)? Can't you do it automatically thru the API ? There are tons more symbols listed with IB not found on Sierra Surely I can't be the only IB user wanting to trade these symbols.. Frustrating 2/ Implement custom-defined (or add 15 min, 2 hr, 4 hr) timeframes? Date Time Of Last Edit: 2014-05-11 07:35:12
[2014-05-10 20:01:28] |
You do not have to ask us to add symbols. How do you conclude that? The IB API provides no provision at all to look up symbols. You can use any symbol you like within Sierra Chart. Refer to step 24 here: http://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-11 07:36:06] |
1/ No That's the point Sierra does not have these symbols on the available list (Find Symbol > ): KRW (Korean Won futures), IBAA (Bovespa index futures) etc Tons of others are missing too. Just compare at IB's available symbols universe & Sierras (Find Symbol >...) https://www.interactivebrokers.com/en/index.php?f=marginnew&p=fut] Seriously deficient Point is WHY does this happen? Does Sierra (you lot) have to do it manually for every missing or new symbol? Why isn't this stuff done automatically thru the API! Surely I can't be the only one wanting to look at charts of these symbols 2/ Implement custom-defined timeframes or have 15 min, 2 hr, 4 hr timeframes? Date Time Of Last Edit: 2014-05-11 07:46:20
[2014-05-11 09:03:21] |
1. Symbols have to be added manually and is a time-consuming process because a lot of information has to be looked up and verified including checking with exchange websites. It is not a simple process. This is not automatic. 2. You can do this. Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-11 09:03:43
