Date/Time: Sun, 16 Mar 2025 03:00:48 +0000
acsil s_UseTool - cannot delete my text/lines
View Count: 726
[2022-08-09 10:14:19]
User92573 - Posts: 548
Dear Support
I'm currently using the s_UseTool in my study to insert text/lines on my charts but when I select "Erase All Lines" mine are the only tool values that remain.
In my scenario the only way to remove them is either individually or via Manage Chart Drawings.
I expect I've missed a parameter in my code that's necessary to allow "s_UseTool" to delete my chart text/lines, or alternatively, I've included a parameter that prevents the drawing from being deleted unless specifically selected..
Any help appreciated.
Many thanks
[2022-08-09 11:26:53]
Sierra_Chart Engineering - Posts: 18796
Yes this is true and is explained here:
Chart Drawing Tools: Erasing Chart Drawings
Drawings added by custom studies would not be deleted with this command.
Date Time Of Last Edit: 2022-08-09 11:26:59
