Date/Time: Thu, 10 Sep 2026 19:30:34 +0000
Copy chart drawings to different chartbook
View Count: 875
| [2022-08-09 07:05:17] |
| Mustang77 - Posts: 122 |
Hi if i have two different chartbooks, with same symbol, for example ES on chartbook 1 and ES on chartbook 2. is it possible to copy chart drawings from ES chartbook 1 to chartbook 2 ? I know how to copy drawings from one chart to another within the same chartbook, but i want to do it to a different chartbook. Thank you |
| [2022-08-09 11:17:47] |
| Sierra_Chart Engineering - Posts: 24822 |
Yes this is supported. Refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
