Date/Time: Sun, 16 Mar 2025 02:52:00 +0000
data question
View Count: 418
[2022-08-08 22:07:12] |
User500207 - Posts: 5 |
A basic question I have pkg 11 have amp live account cqg data cme exchange I went through the step common settings allow support sc yes main setting cqg webapi Is the live data denali or cqg ?? I thought I would see (M) by the symbol for denali |
[2022-08-08 22:14:51] |
John - SC Support - Posts: 38678 |
You are not setup to get the Denali data. Having Package 11 is just one part. If you want the Denali data, then follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
