Date/Time: Sun, 16 Mar 2025 02:57:37 +0000
Denali Feed & Sierra Chart Real Time Feed
View Count: 489
[2022-08-08 16:23:32]
EquityBear - Posts: 4
Sierra,
I realized that TSLA-NQTV vs TSLA offer very different information on footprints since NQTV feed is simply NASDAQ. I went through this: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SymbolLimits and got the point where I pressed activate but was given a warning that said if I require real-time data for CME CBOT etc that I had to use Denali.
Is it possible to use have real time equities data w/o the -NQTV while using Denali Feed?
I need to watch ES tape and equity footprints at the same time - if this information help determine best package.
Thank you!
[2022-08-08 19:49:48]
John - SC Support - Posts: 38678
If you want to get the real-time Equities data with the consolidated tape (but without Market Depth data), then you can do this by using our Sierra Chart Exchange Data Feed. You can use this alongside the Denali Exchange Data Feed, there is no issue with this. To get this data, follow these instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
Once you have the exchange active, you will have to change your symbols to remove the -NQTV, at which point you will get the data from the Sierra Chart Exchange Data Feed (and vice versa - if you add the -NQTV your data will be from the Denali NASDAQ TotalView).
Just make sure to also deactivate the NASDAQ TotalView exchange if you are not going to use it for now.
[2022-08-08 21:00:54]
Okay, I've gone ahead with the above. Thank you!
Now, in regards to ES; I must use Denali Feed since ES is not offered on Sierra Chart Exchange Data Feed, correct?
Can I use Denali CME top of book if I only want access to the tape?
[2022-08-08 22:08:57]
Yes, you need to use the Denali data feed for Futures, including ES.
There is no issue with getting data from both the Sierra Chart Exchange Data Feed and the Denali Exchange Data Feed at the same time.
Yes, you can activate the CME non-professional top-of-book if you only need data from the CME exchange and you do not need market depth data. We see you have already made the change and deactivated the exchange you do not need, so you are good with this.
[2022-08-10 11:50:44]
Thanks again John!
Date Time Of Last Edit: 2022-08-10 11:51:05
