Date/Time: Sun, 16 Mar 2025 02:57:36 +0000
V2422
View Count: 331
[2022-08-08 16:22:59] |
User585104 - Posts: 148 |
Just to let you know I have 2 buttons configured to draw different coloured horizontal lines. Since the update they now do not draw horizontal lines but draw a fan of some kind. I checked the config and everything is correct. Rolled back and it is fine again
[2022-08-08 19:45:22] |
John - SC Support - Posts: 38678 |
Can you please attach the file named Sierra4.config to this thread for us to take a look at it. The file is located in the main Sierra Chart installation folder. Refer to the following for how to attach a file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile What version are you on for which it is working properly and what version did you try it on where it did not work? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-08 19:58:48] |
No worries It works as it should on every version, now after rollback this would be 2419. It just didn't work today when I updated to version 2422 Date Time Of Last Edit: 2022-08-08 20:02:28
