Date/Time: Sun, 16 Mar 2025 02:57:36 +0000
MaxConnectionsForSameDevice = 3 after paying for 5 connections.
View Count: 427
[2022-08-08 16:21:54] |
ProfitableTrader - Posts: 22 |
Hello, I paid for 2 additional connections expecting a total of 5. Still getting MaxConnectionsForSameDevice = 3, connection limit exceeded. Here's is the log: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 4 | 2022-08-07 23:35:52.942 Does the service take time to activate? Also, is the number of connections per computer still limited to 3 (i.e the two additional connection can only be used on a second computer?) Thank you! |
[2022-08-08 23:01:37] |
You cannot have four connections from the same device. Yes this is correct: (i.e the two additional connection can only be used on a second computer?)
[2022-08-08 23:46:12] |
Thank you! In that case, can I get a refund for the two additional devices I purchased? I do not have a second computer to run 4th and 5th connections from.
[2022-08-09 11:16:04] |
Sierra_Chart Engineering - Posts: 18796 |
Yes we can do that.
