Date/Time: Sun, 16 Mar 2025 02:51:59 +0000
2nd and 3rd instances using Rithmic data feed and not Denali
View Count: 474
[2022-08-08 16:19:13]
User873130 - Posts: 47
Hi
How can I make my 2nd and 3rd instances use the Denali feed when connected to a Rithmic/CQG feed?
[2022-08-08 19:41:05]
John - SC Support - Posts: 38678
Are these Sub-Instances or completely separate installations?
If separate installations, then are these on the same computer and if not, are any on the same computer or all they all separate?
[2022-08-08 20:42:42]
sub instances on the same computer
[2022-08-08 22:05:32]
Sub-Instances get their data from the Main Instance. Therefore, there is nothing you need to do, your sub-instances are automatically getting the data from Denali through the main instance.
If you thought you were not getting the Denali data since you did not see an [M], then that is because you will not see that symbol in a sub-instance, since it is not connecting directly to the data service.
