Date/Time: Sun, 16 Mar 2025 02:52:00 +0000
connecting DOM with Footprint chart
View Count: 381
[2022-08-08 16:14:16]
countryboy92 - Posts: 91
I am superimposing my DOM to the right of the footprint chart; can I lock the x-axis of the footprint with the current price on the DOM so that the current price on the DOM and Footprint remain in line with each other?
[2022-08-08 19:40:00]
John - SC Support - Posts: 38678
You can probably come close by setting both to the same settings (Constant Range) and having the Constant Range option for "Recenter to Last Price on Every Update". But you will have to manually line up the information to start with. From there, they should stay in sync.
