Date/Time: Sun, 16 Mar 2025 02:49:19 +0000
Total cost for using Sierrachart
View Count: 591
[2022-08-08 15:15:56] |
User326 - Posts: 1 |
Hello, I would like to use sierrachart for trading S&P 500 micro E-minis future contracts with the easy non-professional cme costs. I've opened a stage5 account, connected Dorman Trading with the stage5 account, provided the proper funding and am now awaiting for confirmation that the funds have been received. I believe the only remaining step after confirmation is choosing a package for sierrachart and I am confused on the pricing. It seems to me that there are 2 separate if I want to use Sierrachart with Denali data/real live data feed. The exchange cost which is 33USD for non-professional funded accounts and service package 10 which costs 36USD. Are there any other costs that I haven't mentioned? Am I missing a step towards being able to use Sierrachart for trading the S&P 500 micro E-minis future contracts? Kind regards, Goliko |
[2022-08-08 19:17:47] |
John - SC Support - Posts: 38678 |
You have your information correct. Just to explain further, you will need to be on one of the Integrated Packages in order to be able to connect to your trading service and get the Denali data. The choice of which package depends on what you need in terms of indicators. Refer to the differences here: Description of Service Packages and Pricing: Integrated Packages And then to setup the Denali data, you will follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* There are no other costs. But if you are using the Teton Order Routing Service with Stage 5, then you will also need to go through the Setup Instructions to connect your Sierra Chart to your order routing setup. Refer to the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
