Date/Time: Sun, 16 Mar 2025 02:51:59 +0000
order fill acting weird
View Count: 451
[2022-08-08 14:16:41] |
User130417 - Posts: 14 |
Hi, when i place an order say a buy order, the stop loss moves way down more like 3 times the target, and when i place a sell order nothing happens, the order just stops or disappears, and a loss of -12.5 adde to my npl. What is going on? Regards, Telema |
[2022-08-08 14:32:42] |
Sierra_Chart Engineering - Posts: 18796 |
Are you using the Trading And Current Quote Symbol in Chart >>Chart Settings?
[2022-08-08 14:40:14] |
nope, is set to nothing, should i use that?
[2022-08-08 14:56:34] |
No. From our perspective is hard for us to understand exactly what the issue is. Is this with live trading? The first thing is to verify all of the order types, and price offsets for the Attached Orders. Make sure everything is it shows it should be. For attached orders, refer to: Attached Orders How exactly are you submitting the order? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-08 23:11:54
[2022-08-08 15:09:23] |
i use a pre-set orders, and it does happen for es mini, and not for cl; and when i drag my stop loss closer to my target, it jumps back to where it was before. all my settings are the same, transfered all my settings from an old computer to a new one. my pre-set order settings are not working for me. (1.) this is an example of my pre-set order: 19 target and 12 stop, when i place a trade, it goes to 12 target and 34 stop; please help. (2)When i place a buy order it automatically rejects the order, same for a sell order, and sometimes reverts back to 1 above |
[2022-08-08 15:47:11] |
This a sell order, and look at the target and stop lines:
Attachment Deleted. Private File |
[2022-08-09 16:33:34] |
Make sure you are setting the Attached Orders on the correct Trade Window. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
