Date/Time: Tue, 15 Sep 2026 19:43:26 +0000
Changing ticks per bar for this study
View Count: 606
| [2022-08-08 14:13:38] |
| Jaydtrade - Posts: 123 |
Is there a reason I cannot move the ticks past 2 on this study? When I try to put 4 it just puts 2 back up everytime. Will not let me surpass the 2. See picture attached.
| [2022-08-08 15:04:49] |
| User431178 - Posts: 906 |
You can't change it in VBP settings when it is linked to TPO chart, "Based on TPO Chart", you can only change by altering equivalent setting in TPO.
| [2022-08-08 18:41:33] |
So I need to change it to say "4" for instance in the TPO first? Edit: Did as you said it worked as intended thank you sir.
Date Time Of Last Edit: 2022-08-08 18:43:57
