Date/Time: Sun, 04 Oct 2026 11:19:02 +0000
TEXT by user for lines
View Count: 572
| [2022-08-08 12:07:01] |
| User361939 - Posts: 169 |
Hi, Could you add option for horizontal/vertical line, so user could add his own text next to line and save as template? |
| [2022-08-08 17:38:00] |
| John - SC Support - Posts: 48095 |
You can do this for Horizontal lines using the Horizontal Lines study and using the "Short Name" in combination with the Name Label and then saving out the configurations you want as Study Collections. Refer to the following: Horizontal Lines Chart Studies: Subgraphs Tab >> Short Name Chart Studies: Subgraphs Tab >> Name and Value Labels There is not really an option for Vertical Lines in the same way, but you could try the Time Line study if that will work for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
