Date/Time: Sun, 16 Mar 2025 02:49:20 +0000
Volume Profile drawn along a defined vertical area on the chart
View Count: 410
[2022-08-08 10:41:43]
User13051990 - Posts: 26
Good day,
I have a question regarding the "Draw Volume Profile" tool. Is it possible to have a volume profile drawn along a defined vertical area on the chart without superimposing the profile over the entire highlighted candlestick on the chart?
Greetings!
imageDrawVolumeProfile1.png / V - Attached On 2022-08-08 10:41:31 UTC - Size: 46.98 KB - 87 views
[2022-08-08 11:04:04]
Sierra_Chart Engineering - Posts: 18796
It is possible to right align the profile and it is also possible to control the width of the profile:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Settings
This is the extent of what can be done regarding what you are looking to do.
Date Time Of Last Edit: 2022-08-08 11:10:47
[2022-08-08 11:13:42]
Thanks for a quick response. However, I was going through the documentation and didn’t find what I was looking for. As described I was hoping to somehow draw a volume profile based on a defined vertical price range NOT horizontal.
[2022-08-08 11:14:21]
Please check attached file.
imageDrawVolumeProfile1.png / V - Attached On 2022-08-08 11:14:13 UTC - Size: 46.98 KB - 91 views
[2022-08-08 17:23:44]
John - SC Support - Posts: 38678
This is not supported.
