Date/Time: Sun, 16 Mar 2025 02:55:05 +0000
Deleting a profile
View Count: 418
[2022-08-08 01:40:07] |
Kellie Lacey - Posts: 75 |
Hi, I have profiles set up as buttons where I can create a profile on my charts, to delete these I can just click and delete on them but for some reason it's not allowing me to delete one of them, can someone please help? I've tried to find this in the self help section but can't find anything thanks
[2022-08-08 07:47:53] |
Sierra_Chart Engineering - Posts: 18796 |
If you are referring to the Volume by Price study, you can remove studies through Analysis >> Studies: Chart Studies: Remove (Analysis >> Studies) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-09 11:27:26] |
Many thanks
