Date/Time: Sun, 16 Mar 2025 02:55:03 +0000
Graphics Settings - Chart - Other panel is disabled
View Count: 376
[2022-08-07 23:37:24]
User275839 - Posts: 61
All the right-side checkbox options in the "Other" tab of my Chart Graphics Settings dialog are disabled. I'm using OHLC bars, and have unchecked "Use Global Graphics Settings".
What do I need to do to enable the disabled options in the "Other" tab panel?
See attached screenshot for a visual.
THankS!
imageOHLC_Coloring_Dialog.jpg / V - Attached On 2022-08-07 23:34:54 UTC - Size: 126.27 KB - 106 views
[2022-08-08 16:49:25]
John - SC Support - Posts: 38678
Those particular items are only Global settings. Therefore, they are not available under the Chart Graphics Settings. You would need to change these on the Global Graphics Settings window (General Settings >> Graphics Settings - Global).
