Date/Time: Thu, 19 Sep 2024 21:48:41 +0000
Will you be adding the USD/GBP,USD/CNH,and EUR/RUB to the BTC-E feed
View Count: 1413
[2014-05-10 06:44:02] |
User13065 - Posts: 6 |
Will you be adding the USD/GBP,USD/CNH,and EUR/RUB to the BTC-E feed along with the other new products
[2014-05-10 19:56:48] |
There are no plans for this. We do not want to add too many symbols. For two reasons. Bitcoin data feeds which Sierra Chart connects to from our own servers, are very substandard. They are not reliable well-designed data feeds which are designed to track lots of symbols. If we add support for too many symbols, there is a good chance we lose some data for other symbols. In the case of the foreign exchange, you really should be trading these markets through reputable and established Forex trading services with quality data feeds and trading back ends. You really should be working through a Forex trading service where you can establish the bid and ask prices yourself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-10 19:57:35
[2014-05-11 15:34:11] |
yoytu - Posts: 59 |
MT 4 data feed is pretty much standard on forex i dont understand how the MT4 data feed from btc-e is sub par
[2014-05-13 06:11:56] |
They may be using a completely different connection to btc-e and not an HTTP polling method.
