Date/Time: Sun, 16 Mar 2025 02:49:20 +0000
Horizontal line/Modify text - How to adjust Font size?
View Count: 672
[2022-08-07 14:23:36] |
HeyUgly - Posts: 251 |
hello for some reason my text has gone huge I draw the horizontal line study then i select modify text to add a note on that line like i always do But when i write here, theres no place to adjust the font size. Where can i do this?? |
[2022-08-08 15:33:46] |
John - SC Support - Posts: 38678 |
For drawings where you can not select the font size (like Line or Horizontal Line) then the font is controlled on the Tools >> Tool Settings window under the entry for General >> Global Chart Drawing Font. Refer to the information here: Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
