Date/Time: Sun, 16 Mar 2025 03:00:48 +0000
ayuda para poder tener datos reales
View Count: 524
[2022-08-07 10:21:32] |
User225133 - Posts: 2 |
hola buenas tengo amp sierra chart denail llevo unos dias intentado tener datos reales pero nada me da error al cargar los grafico tengo el paquete 11 de sierra ya nose que hacer e intentado todo
[2022-08-07 13:40:46] |
Sierra_Chart Engineering - Posts: 18796 |
Buenas, You also need to activate the exchanges you need real-time data for, here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Let us know if you need help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-07 14:54:13] |
Si necesiro ayuda estoi perdido nose que hacer llevo ya desde el viernes desesperando intenta nose si es por amp por algo de sierra nose si nesexito pagar algo extra en sierra o amp me da los datos estoy perdido
[2022-08-08 15:56:28] |
SC Support - Posts: 1941 |
Spoke to Adrian, Christine helped with a few set-up questions
