Date/Time: Sun, 16 Mar 2025 02:46:46 +0000
issue with filling the area beetween two donchian channel highs
View Count: 386
[2022-08-07 07:49:58] |
User275592 - Posts: 97 |
Hi, i am trying to fill with color the area beetween two donchian channel high curves I put on my graph two donchian channel studies and the Study Subgraphs Refrerence. i set the scale to automatic Everything is ok but there is a little difference beetween the donchian lines and the fill I tried to find the solution by myself but did not succeed Thank you for your help |
[2022-08-07 07:53:14] |
https://www.sierrachart.com/image.php?Image=1659858748483.png
[2022-08-08 15:20:01] |
John - SC Support - Posts: 38678 |
Make sure the Scale Setting for the Study Subgraphs Reference is set to Automatic. Typically this is the cause of this, and it is not set to Automatic by default.
[2022-08-08 17:20:48] |
Hi, thank you for your message / the scale setting is already on automatic thank you for your help
[2022-08-08 21:16:37] |
Please attach a chartbook with that chart in it so we can take a look. Something is not set correctly is all we can say at this point. Refer to the following for how to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-08 21:28:32] |
i send you the chartbook thank you for your help |
![]() Attachment Deleted. |
