Date/Time: Sun, 16 Mar 2025 02:55:04 +0000
How to automatically download/update data for large amount of tickers.
View Count: 323
[2022-08-06 17:26:05] |
Perseus - Posts: 30 |
I need to review a large number of stocks (100+) and would like SC to automatically download and/or update tick data for these tickers automatically before I start reviewing the symbols. Preferably without opening a chart for each symbol. Is this sort of batch update possible? Thanks.
[2022-08-08 14:56:33] |
John - SC Support - Posts: 38678 |
Refer to the following: Global Settings Menu: Intraday File Update List (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-08 15:08:38] |
Thank you, that will work nicely.
