Date/Time: Mon, 17 Mar 2025 10:42:38 +0000
vbp monthly
View Count: 350
[2022-08-06 17:02:50] |
User411320 - Posts: 303 |
is there a reason the monthly volume profile starts on the 13th of every month and not the 1st?
[2022-08-08 14:53:08] |
John - SC Support - Posts: 38678 |
If you have set the following: - Volume Graph Period Type to Multiple Profiles Based On Fixed Time - Time Period for Fixed Time to Months - Time Period Length for Fixed Time to 1 Then your VbP should be starting on the first day of each month, as you would expect. The reasons we can think of as to why this might not be the case are the following: - Less than 1 month of data loaded in the chart, so the only data starts on the 13th of the month - Using different settings from above. Particularly using Days with a length of 30 (or 31). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-08 18:50:11] |
this worked thank you
