Date/Time: Sun, 16 Mar 2025 02:57:36 +0000
Sierra Chart Licence
View Count: 395
[2022-08-06 11:39:33] |
User660033 - Posts: 2 |
Hola Amigos, OS escribo desde EspaƱa. Quiero usar el Sierra chart con Uprofit. U profit me brinda los datos de mercado a travez de Rhitmics. Pregunta: Puedo comprar SOLO LA LICENCIA DE sIERRA CHARTS SIN DATOS DE MERCADO ? Pregunta 2: CUANTO CUESTA MENSUALMENTE LA CUOTA DE SOLO LICENCIA PARA SIERRA CHART Pregunta 3: Con solo licencia de Sierra chart y los datos de Rhitmics, puedo usar DOM y el volume profile (todas las modalidades). Muchas gracias un cordial saludo Vladi |
[2022-08-08 14:42:45] |
John - SC Support - Posts: 38678 |
From Google Translate: Hello friends, I write to you from Spain. I want to use the Sierra chart with Uprofit. U profit provides me with market data through Rhitmics.
Question: Can I buy JUST THE SIERRA CHARTS LICENSE WITHOUT MARKET DATA? Question 2: HOW MUCH IS THE MONTHLY LICENSE ONLY FEE FOR SIERRA CHART Question 3: With only Sierra chart license and Rhitmics data, I can use DOM and volume profile (all modes). Thank you very much, cordial greetings Vlady 1. Yes, you can use Sierra Chart with the Rithmic data. Just be aware of the issues outlined at the following link: Rithmic Trading Platform Service: Rithmic Support Policy 2. You will need one of the Integrated Packages (Package 10, 11, or 12). Refer to the differences in the packages at the following link: Description of Service Packages and Pricing: Integrated Packages 3. Yes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
