Date/Time: Sun, 16 Mar 2025 02:57:35 +0000
[User Discussion] - pro/non pro nasdaq totalview subbscription
View Count: 388
[2022-08-06 10:55:48]
User565928 - Posts: 1
hello id like to knpw if as non professional when itsonly written "nasdaq us stock data" it means nasdaq "level 1" or nasdaq "level 2". If i want nasdaq level 2 should i qualify as a professional or should i only pay for non professional and ill get nasdaq level 2 ? Thanks
[2022-08-08 14:34:59]
John - SC Support - Posts: 38678
Both the Non-Professional and the Professional exchange options include Level 2 market depth. Therefore, you need to activate the exchange option that fits your particular situation - that is, if the exchange considers you a Professional, then you need to activate the Professional exchange. Otherwise, you are a non-professional and should activate the non-professional exchange.
