Date/Time: Sun, 16 Mar 2025 02:55:04 +0000
The Chartbook file is not compatible. Contact support for help with converting it.
View Count: 610
[2022-08-05 19:48:07]
LipinRD - Posts: 4
Hi! how can I make my xxx.cht file compatible?
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-08-05 19:47:42 UTC - Size: 276.18 KB - 151 views
[2022-08-05 20:19:54]
John - SC Support - Posts: 38678
Attached is your updated chartbook.
Date Time Of Last Edit: 2022-08-05 20:20:10
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-08-05 20:20:07 UTC - Size: 20.43 KB - 263 views
[2022-08-06 08:21:15]
Sierra_Chart Engineering - Posts: 18796
Where did you get this Chartbook from?
Date Time Of Last Edit: 2022-08-06 08:21:21
[2022-08-07 01:16:25]
LipinRD - Posts: 4
A friend gave it to me. it was from a course he did
[2022-08-09 19:25:40]
Ok thank you. We are getting a lot of requests to convert these Chartbooks and if we know where they are coming from we can tell the provider of them to convert them.
