Date/Time: Sun, 16 Mar 2025 02:52:00 +0000
Profile only?
View Count: 435
[2022-08-05 16:55:52] |
User731023 - Posts: 144 |
Is there a way to just show the profile and not the numbers? Thanks |
[2022-08-05 17:55:45] |
John - SC Support - Posts: 38678 |
Change the setting for Chart >> Chart Settings >> Display >> Hide Volume Numbers From Current Traded Volume Columns to Yes.
[2022-08-05 19:00:43] |
If I go to Chart >> Chart Settings >> Display is not an option/choice. Grrrrrrr PS Please clarify how to get to Display section. Date Time Of Last Edit: 2022-08-05 19:01:44
[2022-08-05 19:55:13] |
It looks like you are on an older version with the old Chart Settings window. Therefore this option is not available. If you can upgrade to the current release then you will be able to use this option. Refer to the following to upgrade: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
