Date/Time: Sun, 16 Mar 2025 02:49:18 +0000
cannot connect to trading service
View Count: 440
[2022-08-05 15:43:36]
User27182 - Posts: 15
recently switched to level 10 w Denali data ran for 2 weeks = ok with CQG trading service
read that i shud notify Amp that switched when i did they shut off CQG data
& charts stopped...
then I switched to SC all services in the trade service tab
said YES to edit & translate symbols = OK with charts
tried to test trading service by switching from SIM trading[green] to Live trading [yellow]
and 3-4 times in a row it would not execute with CQG? with anybody & switched back to Sim trading
& executed there.
What can I do -inquires to Amp say to check with Sierra
what's next find a new trading service??
[2022-08-05 17:14:41]
Sierra_Chart Engineering - Posts: 18796
You also need to activate the exchange that you need here:
And the Global Settings >> Data/Trade Service Settings >>Current Selected Service in Sierra Chart in your case needs to be set to CQG Web API.
Date Time Of Last Edit: 2022-08-05 17:40:13
[2022-08-07 14:38:45]
this solution does not appear to work for me
CQG WebAPI does NOT produce charts -
all data stops on the day they cut CQG data off = 7-22-2022
said YES to edit & translate symbols = ---------------> OK with charts
but charts don't execute in live trading-just kicks me back to SIM trading
to complicate matters I just updated to current version 2419 64 bit
AMP doesn't support Teton - so, I am out of luck with that....
don't see the need for Denali if i can't trade it....
if i don't use Denali - can i go back to pkg #3??
So i figure that getting AMP to restart CQG data is my solution.
unless you can see a way around this...I need CQG WebAPI to trade - right?
[2022-08-07 23:37:37]
looks like your advice did fix it!!!!
did not have any money in acct to pay for exchange fees - because the month had changed
thank you!!
[2022-08-08 04:21:05]
Let us know if you need further help.
