Date/Time: Sun, 16 Mar 2025 02:49:20 +0000
Movable Stop Indicator on Chart
View Count: 388
[2022-08-05 14:50:20] |
johnnybass99 - Posts: 1 |
How can I add a visual marker on my chart for my stoploss that I can move up/down by dragging it on my chart? Thanks!
[2022-08-05 15:05:12] |
John - SC Support - Posts: 38678 |
You should have a Position line indicator in general. To define what is shown in that line refer to the following: Global Trade Settings Windows: Chart Position Line (Global Settings >> Chart Trade Settings >> General) And you can grab and move that position line. If you have issues adjusting the Stop, then refer to the following: Attached Orders: Unable to Modify Price of Attached Orders For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-05 15:05:28] |
