Date/Time: Sun, 16 Mar 2025 16:59:31 +0000
imbalance blocks alert formula
View Count: 513
[2022-08-05 11:29:32]
MarcOh - Posts: 171
Can somebody (maybe a user) help me to figure out the formula for a costum study (see attachment).
Every time an imbalance is created, i want an alert after bar close.
Im confused since hours. alert study, color based, formula, global settings...
i would be very very grateful to you..,
M.
imageScreenshot_2.png / V - Attached On 2022-08-05 11:28:56 UTC - Size: 124.06 KB - 135 views
[2022-08-05 14:02:49]
John - SC Support - Posts: 38678
Since this is a custom study there is little we can do to help, since we do not know how the information is processed or what is made available to you.
In general, there would be subgraphs that define the information and you would just need to check if a subgraph (or probably subgraphs, one for each item) is non-zero. But again, we can not say whether this is exactly the way this study is made.
You may need to ask the developer.
