Date/Time: Mon, 17 Mar 2025 09:45:15 +0000
Auto-Scroll Charts
View Count: 445
[2022-08-05 11:06:07] |
User785258 - Posts: 12 |
Dear Sirs: I was wondering if someone could guide me with the following issue I am trying to solve: Settings: Graphics Settings > Global > Other > Default Right Side Fill Space = 8% Currently candles are printed in the 8% space on the lower timeframes, and although the last candle is visible, the space is not maintained. Would it be possible for any/ all charts to maintain the set minimum 8% margin? Rather than having to press 'End' to readjust the chart. With thanks, Ben |
Attachment Deleted. ![]() |
[2022-08-05 12:03:42] |
Sierra_Chart Engineering - Posts: 18805 |
Yes enable locking the fill space: Chart Menu: Lock Fill Space (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
