Date/Time: Thu, 24 Sep 2026 06:25:33 +0000
Rename and Compile an Existing SC Study for Distribution
View Count: 1358
[2022-08-05 06:36:17]
User429065 - Posts: 130
In an effort to protect a proprietary combination of studies within the "Study Subgraphs Average - Multiple" study, I'm renaming it within the code using Notepad++, then trying to compile it using SC Remote or Visual Studio. Eventually, I'll protect it with a password. After several hours of following the "step-by-step instructions", I'm still not getting the required DLL file (see the attached result). Please advise, thank you very much!
#include "sierrachart.h"
#include "scstudyfunctions.h"
SCSFExport scsf_TrendeX(SCStudyInterfaceRef sc)
  SCSubgraphRef Subgraph_Average = sc.Subgraph[0];
  SCFloatArrayRef Array_SubgraphCount = sc.Subgraph[0].Arrays[0];
  if (sc.SetDefaults)
    sc.GraphName = "TrendeX";
    sc.ValueFormat = 3;
    sc.AutoLoop = 0;//manual looping
    sc.CalculationPrecedence = LOW_PREC_LEVEL;
    Subgraph_Average.Name = "TrendeX";
    Subgraph_Average.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_Average.LineWidth = 2;
    Subgraph_Average.PrimaryColor = RGB(0, 255, 0);
    Subgraph_Average.DrawZeros = false;
    int StudyReferenceIndex = 0;
    for (int InputIndex = 0; InputIndex < 40; InputIndex += 2)
      StudyReferenceIndex++;
      sc.Input[InputIndex].Name.Format("Use Study Subgraph Reference %d", StudyReferenceIndex);
      sc.Input[InputIndex].SetYesNo(false);
      sc.Input[InputIndex + 1].Name.Format("Study Subgraph Reference %d", StudyReferenceIndex);
      sc.Input[InputIndex + 1].SetStudySubgraphValues(0, 0);
    return;
  int NumberUsedSubgraphs = 0;
  int CalculationStartIndex = sc.GetCalculationStartIndexForStudy();
  sc.EarliestUpdateSubgraphDataArrayIndex = CalculationStartIndex;
  for (int SubgraphIndex = 0; SubgraphIndex < 20; SubgraphIndex++)
    if (!sc.Input[SubgraphIndex * 2].GetYesNo())
      continue;
    SCFloatArray StudyArray;
    sc.GetStudyArrayUsingID(sc.Input[SubgraphIndex * 2 + 1].GetStudyID(), sc.Input[SubgraphIndex * 2 + 1].GetSubgraphIndex(), StudyArray);
    if (StudyArray.GetArraySize() == 0)
      continue;
    NumberUsedSubgraphs++;
    for (int BarIndex = CalculationStartIndex; BarIndex < sc.ArraySize; BarIndex++)
      if (NumberUsedSubgraphs == 1)
        Subgraph_Average[BarIndex] = 0;
        Array_SubgraphCount[BarIndex] = 0;
      //If the input subgraph is zero at this bar index, then do not include it in the average.
      if (StudyArray[BarIndex] == 0)
        continue;
      Subgraph_Average[BarIndex] += StudyArray[BarIndex];
      Array_SubgraphCount[BarIndex] += 1;
    if(Array_SubgraphCount[BarIndex] != 0)
      Subgraph_Average[BarIndex] /= Array_SubgraphCount[BarIndex];
Date Time Of Last Edit: 2022-08-05 06:38:36
imageBuild DLL.JPG / V - Attached On 2022-08-05 06:16:40 UTC - Size: 38.97 KB - 208 views
[2022-08-05 10:59:41]
Sierra_Chart Engineering - Posts: 24949
When you build this, we need to see the entire build output, so we can see the errors.
Date Time Of Last Edit: 2022-08-05 10:59:55
[2022-08-05 14:56:16]
John - SC Support - Posts: 47994
You are trying to build a header file, not a .cpp file. Also, the remote build option does not work with separate header files, you would need to have everything in the .cpp file. Refer to section 19.9 at the following link:
Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function
