Date/Time: Sun, 16 Mar 2025 03:00:47 +0000
CME Rithmic Data Check
View Count: 349
[2022-08-05 04:39:47] |
jborg - Posts: 14 |
I am using Denali data on SC. However I would like to use Rithmic to check off the monthly CME fee payment requirement and then go back to the Denali feed via the Global Settings as described in manual. I followed the directions in the manual but to no avail. Is this still possible consider the changes at Rithmic? Can someone provide some guidance? Thanks Joal |
[2022-08-05 05:35:25] |
Sierra_Chart Engineering - Posts: 18796 |
We can see that you did successfully connect to your funded futures trading account: Verified trading account ending date: 2022-09-04
To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
