Date/Time: Sun, 16 Mar 2025 03:00:47 +0000
missing data from the study
View Count: 467
[2022-08-04 23:14:34] |
traderz - Posts: 4 |
Hello, I set up a 180 minutes chart to filter out some volume at certain price level. In "volume at price threshold v2" ---> "number of days to calculate" property, it is set to "180 days" and "comparison method" is set to "total volume" However it seems the lines which match the criteria is limited to less than 60 days regardless I ever lowered the threshold for "total volume" to lower number. I use "bid volume and ask volume difference", it seems the same result to limit to only 60 days or so. I attach the some screenshots to illustrate. Btw, in "chart settings" ---> "date limiting", the "days to load" is set to 180 days Please advise, Thanks, |
Attachment Deleted. Private File Private File |
[2022-08-05 10:22:03] |
Sierra_Chart Engineering - Posts: 18796 |
Add this study to the chart: Bid Volume vs Ask Volume After that, provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image If there is any missing bid/ask volume data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-05 12:37:07
[2022-08-05 22:33:21] |
Thank you for the reply. I follow the instruction and add "bid volume vs ask volume", and "delete and redownload all data" again, the data is still not 180 days, but 60 days. Here is the screenshot link: https://www.sierrachart.com/image.php?Image=1659738609202.png FYI, I also take screenshot of both studies to show the settings in case needed. Thanks, |
[2022-08-06 02:56:58] |
Set the chart to a Continuous Futures Contract chart: Continuous Futures Contract Charts And re-download data for all contract months. Instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-06 23:49:13] |
Thank you for prompt response. It works! The issue is the setting of "continuous future contract". Thanks a lot!
