Date/Time: Tue, 06 Oct 2026 05:15:58 +0000
Historical NQ data
View Count: 635
[2022-08-04 21:08:01]
User812728 - Posts: 26
How can I look back to 2020 on the NQ? I can only look back to May 2022 since the only contract available in 'find symbol' is the ENQM22 June 2022. Please provide some help !
[2022-08-04 21:27:32]
John - SC Support - Posts: 48114
You can either use a Continuous Futures Contract and load the number of days you want. Refer to the following:
Continuous Futures Contract Charts
Or you can enter the specific symbol on the Find Symbol window using the symbol format for the current symbols and then selecting to open an Intraday or an Historical chart. For example, if your current symbol is ENQM22 then if you want the M contract for ENQ back in 2020, then you would enter ENQM20.
