Date/Time: Sun, 16 Mar 2025 02:57:36 +0000
ø
View Count: 238
[2022-08-04 20:22:44] |
sgne - Posts: 109 |
ø
Date Time Of Last Edit: 2024-12-05 04:04:44
[2022-08-04 20:31:31] |
John - SC Support - Posts: 38678 |
If the particular instrument that you are tracking does not have trading occurring more than once per second, then the one option available would be to use the Chart Recalculation - Periodic study and set it to recalculate every 1 second. You would also want to set your Chart Update Interval to be an even divisor of 1 second (i.e. 200, 250, 500 milliseconds, but not 300 or 400). Having this setup would allow you to correctly gather 1 second increments, but it is somewhat costly to force a recalculation of the chart every 1 second, particularly if you have several other studies on the chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-04 20:31:47
