Date/Time: Sun, 16 Mar 2025 02:55:05 +0000
switching to new computer problems
View Count: 439
[2022-08-04 15:27:57]
User266838 - Posts: 13
installed sierra 2419 on new computer; cant get live-- only delayed; finally got live account installed --now i've lost sim mode;thx for help!!
[2022-08-04 16:09:38]
John - SC Support - Posts: 38678
Our servers are showing that you are not connected to your data/trading service. What service do you use?
[2022-08-05 14:44:05]
john i have teton cme for new computer (cqg on old) and it shows not connected because i dont have a acct signed to this acct.This is wierd because my trading acct # is showing on the dom and i have lost my SIM that i want. I'm screwed!!
[2022-08-05 14:59:38]
If you are using the Teton Order Routing Service on your new computer then go through the Setup Instructions at the following link and start at Step #5. Note that you will have to use the Denali Exchange Data Feed for your data when using the Teton Order Routing Service.
Sierra Chart Teton Futures Order Routing: Setup Instructions
