Date/Time: Thu, 28 Nov 2024 05:56:23 +0000
Converting CHT file to current sierra version
View Count: 950
[2022-08-04 15:12:40] |
dberliner - Posts: 16 |
Hi Sierra support or anyone else who knows how to convert an older CHT file to current sierra versions. Would really appreciate your help. Getting the message "The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it". The file is attached. Thanks, Dberliner Date Time Of Last Edit: 2022-08-04 15:13:04
PercentAverageDailyRangeCalculation.cht - Attached On 2022-08-04 15:10:28 UTC - Size: 125.99 KB - 193 views |
[2022-08-04 15:55:35] |
Attached is your updated chartbook.
PercentAverageDailyRangeCalculation.cht - Attached On 2022-08-04 15:55:30 UTC - Size: 7.1 KB - 181 views |
[2022-08-05 10:56:08] |
mjfatahi - Posts: 2 |
Hi Sierra support or anyone else who knows how to convert an older CHT file to current sierra versions. Would really appreciate your help. Getting the message "The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it". The file is attached. Thanks, |
Attachment Deleted. Private File |
[2022-08-05 13:41:17] |
Attached is the updated chartbook.
G7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-08-05 13:41:13 UTC - Size: 20.43 KB - 210 views |
[2023-05-17 11:30:19] |
Muhammad Idrees - Posts: 1 |
its solution is download old version seirra then open in old seirra and then close chart and save for current date. Next then copy that 2 files from old downloaded data folder and paste into new version data folder.
[2023-05-24 19:10:18] |
User285436 - Posts: 3 |
Request - Converting old .Cht files to new version
Attachment Deleted. Private File Private File |
[2023-05-24 22:28:32] |
Follow the instructions here: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
